blackhawk34a
May 19, 2020Guide
c7800 drops internet, wifi stays connected +DOS attacks
This has been a persistent problem since I got this modem/router. Have Xfinity service. Randomly throughout the day the internet will drop connection. The wifi signals continue to broadcast but my an...
blackhawk34a
May 19, 2020Guide
Next couple post will be of cable connection statistics. Couldn't get them to format when trying to post them as text. So a coulple snips instead. Sorry for inconvenience.
blackhawk34a
May 19, 2020Guide
- plemansMay 19, 2020Guru - Experienced UserI would wait on the tech to replace the line. You have a lot of errors in the line.
- blackhawk34aMay 19, 2020Guide
Thanks for the quick reply. I can't read the values as being good or bad, so I appreciate your help. My skillset is elseware. The techs always seem to check the line the outside of the house and says it's good. So maybe it would be the house wiring.... I had an appointment to get that changed, but with this virus crap they canceled that saying they can't enter the residence. Maybe I can get the guy to leave me some line so I can run one myself.
directly connect the modem where it enters the home. On reboot the values should refresh so you can watch for an increase in errors in your line. If you don't get any, then its the wiring in the home. If you do, its external.
That'd be what I'd do.
