Soul22
Jan 06, 2021Tutor
C7800 errors and disconnects
Log code says: critical 3 Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=44:a5:6e:b4:62:48;CMTS-MAC=00:a3:d1:5d:61:5b;CM-QOS=1.1;CM-VER=3.1; What on earth does that...
michaelkenward
Jan 07, 2021Guru - Experienced User
You have posted your message in the section of this community given over to Nighthawk WiFi Routers. (This is easily done, given Netgear's impenetrable community structure.)
You might get more help, and find earlier questions and answers about your hardware, in the appropriate section for your device. That's probably here:
Cable Modems & Routers
I will ask the Netgear moderator to move your message.
also, screen snips are easier to read.
I'd also get a snip of the cable connections page.
