StephMiller03
Mar 03, 2022Follower
C7800 Firmware Update Issue
My modem/router combo keeps losing connection. After some digging online I found that I can download the netgear app to see what's possibly wrong with my machine. Well it tells me that the firmware ne...
freemandennis
Jun 03, 2022Tutor
I fought with this between xfinity and netgear. Do a factory reset within the modem portal. It will automatically do a firmware upgrade. Mine is now updated and I hope my connection issues are resolved.
Jun 03, 2022Guru - Experienced User
What FW version is now loaded on the modem?
- freemandennisJun 03, 2022Tutor
I went from V3.01.38 to V6.01.07. I believe that is the latest.
- FURRYe38Jun 03, 2022Guru - Experienced User
Thank you.
