estravada
Jul 01, 2020Aspirant
C7800 Lan Port stopped working
My C7800 LAN Ports just stopped working 3 days ago and I have been trying to troubleshoot it since then. I am using the LAN to connect to my NVR as well as my desktop PC, but none of them are abl...
Jul 01, 2020Guru - Experienced User
does it work over wireless?
What are all the led's doing?
Is your ISp able to ping/see the C7800?
- estravadaJul 01, 2020AspirantWifi works perfectly in both 2.4GHz and 5GHz band.
The LEDs on the router usually blink when there is a tranmission of data. The ones on wifi is working, but there is no LED light on the LAN ports. It used to have before that to show that LAN is working and connected- plemansJul 01, 2020Guru - Experienced User
Do any of the ports work?
Have you tried a different device and cables?
I know you said cables but its worth a shot.Have you tried a factory reset?
- estravadaJul 01, 2020AspirantI tried connecting to all the 4ports, but nothing works. Tried with laptop which is always on Wifi, but still not working. I will try factory reset later tonight. That is the one thing left to be done.
By doing factory reset, will I will be able to connect back to Xfinity by just plugging in the cable? I am not able to recall if the installer made any settings during the installation
