Byteman007
Jun 23, 2019Initiate
C7800 modem firmware update
I am trying to get updates to c7800 cable modem/router combo product. I am on Xfinity comcast. Your website under download section says ISP will update firmware. Comcast says they don’t update firmwar...
schumaku
Jun 23, 2019Guru - Experienced User
Lot of noise without providing any insight or issues you expect to be addressed with whatever update. What is your C7800 current firmware version?
Either way, cable modem and cable router firmware is ISP specific requiring mandatory certification and/or validation - What’s the latest firmware version of my NETGEAR cable modem or modem router?
Netgear does provide the firmware, the update is not under user control. That's why there are no downloads made available to the public. Pretty much convinced the ISP helpdesk information is not correct.
PS. I'm not Netgear, and more than happy we don't have this Nightmare overseas - here most if not all Cable TV ISP don't allow 3rd party cable modem/routers. Christian_R please shed some light to the mis-informed community member(s).
- Byteman007Jun 23, 2019InitiateIssue is that my modem/router drops 5g speeds to less than 64kb pretty much every week if i dont use 5g enabled/connected devices eg: Apple TV 4k connected through 5g wifi streaming from various sources.
I shouldnt have to power down or reboot or reset from Xfinity app. Its a pain and Netgear should release a fix and work closely with Comcast to support this product. Otherwise; its misleading consumers that its a Cable modem+Router combo that is superior than other options. People don’t buy products like these with expectations that its a snapshot in time with no updates ever again.; especially for an important piece of hardware that connects your entire home from ISP and inside. Thats BS for a $450 product.- FURRYe38Jun 23, 2019Guru - Experienced User
Any Wifi Neighbors near by? If so, how many?Set 20/40Mhz Coexistence to 40Mhz only.
Have had no 5Ghz issues with mine. Though mines now in bridge mode using a Orbi system.
ISP do all FW updates for any modem connected to there system, however some ISP don't update FW on customer owned modems. Seen this before with some ISPs.
If this is the case with your ISP, I recommend getting into a modem only unit or use one of there modem only units so you know you'll get FW updates on the modem and install a external wifi router which is something you can get FW updates to and manually update FW yourself.
