eddie2023
May 31, 2023Aspirant
C7800 Netgear - I have to reset my router every day.
Like the title says, I have to reset my router everyday once or twice for WIFI to work. This is NETGEAR Nighthawk C7800 It only affected my WiFi devices, but not anything hardwired. I tried resetti...
Jun 01, 2023Guru - Experienced User
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Has a power off for 1 minute then back ON with the modem been performed?
Turn off and unplug modem.
Turn on computers and rest of network.
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-router
Please post a copy and paste of the modems connection status page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
You have some Criticals and Warnings that the ISP needs to review and resolve.
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Start with removing any amplifiers, signal attenuators, or splitters from the coax.
From there check the line for kinks, damage, moisture in the line.
Check the connectors for improperly made ends, foil touching the copper coax line, loose connections, bad/old/cheap connectors, or corroded connections. Replace them if you do.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html
This is NETGEAR Nighthawk C7800It only affected my WiFi devices, but not anything hardwired. I tried resetting my router, flashing the firmware, playing with QoS, adding a bunch of static IPs, changing WiFi channels, etc. but nothing worked.
The only temporary workaround is to reboot my router. This has become very annoying.. If I travel for a few days, my RING disconnects on the same day and stop working until I am back and restart the router. This is really very frustrating as I am thinking about buying a new router (This router cost me around $370)!!
My wired devices NEVER disconnects. ONLY WIFI. I tried to open a ticket but it seems I am out of warranty as I bought this probably two years ago.
I looked at the event logs, I see the below data (I will delete my personal info like MAC addresses).. Do you think this is related? If not, then can someone please provide some guidance on what can I do as I am out of ideas.
Time Priority Description 2023-05-31, 21:18:32 Notice (6) CM-STATUS message sent. Event Type Code: 5; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=<MAC-ADDRESS HERE>;CMTS-MAC=<MAC-ADDRESS HERE>;CM-QOS=1.1;CM-VER=3.1; 2023-05-31, 21:18:25 Warning (5) Dynamic Range Window violation 2023-05-31, 21:18:25 Warning (5) RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=<MAC-ADDRESS HERE>;CMTS-MAC=<MAC-ADDRESS HERE>;CM-QOS=1.1;CM-VER=3.1; 2023-05-31, 21:18:24 Warning (5) REG-RSP-MP Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=<MAC-ADDRESS HERE>;CMTS-MAC=<MAC-ADDRESS HERE>;CM-QOS=1.1;CM-VER=3.1; 2023-05-31, 21:18:20 Notice (6) DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=<MAC-ADDRESS HERE>;CMTS-MAC=<MAC-ADDRESS HERE>;CM-QOS=1.1;CM-VER=3.1; Time Not Established Notice (6) Honoring MDD; IP provisioning mode = IPv6 Time Not Established Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=<MAC-ADDRESS HERE>;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1;
