eddie2023
May 31, 2023Aspirant
C7800 Netgear - I have to reset my router every day.
Like the title says, I have to reset my router everyday once or twice for WIFI to work. This is NETGEAR Nighthawk C7800 It only affected my WiFi devices, but not anything hardwired. I tried resetti...
eddie2023
Jun 01, 2023Aspirant
Thanks for your response.. Look at the below answers.
>> Why? What happens that forces you to reset the modem/router?
Wifi just stops working. No internet until I restart my router.
>> The comment about firmware is puzzling. The C7800 is a modem/router. Only your ISP can flash it.
You are correct. I confirmed that I have the latest firmware from my service provider.
>> Your subject says "reset" which is not the same thing as reboot. Which is it?
I unplug the power from the router for 2-3 minutes then plug it back in and the wifi starts working.
This is AC3200 Wifi Cable Modem Router
Model: C7800
Where can I find documentation about troubleshooting? I couldn't find anything helpful. Thank you
Jun 01, 2023Guru - Experienced User
got a screensnip of the cable connections page?
You're getting power window violations indicating your power is going out of range.
But without knowing if you're high or low, its tough to tell you where to start.
