eddie2023
May 31, 2023Aspirant
C7800 Netgear - I have to reset my router every day.
Like the title says, I have to reset my router everyday once or twice for WIFI to work. This is NETGEAR Nighthawk C7800 It only affected my WiFi devices, but not anything hardwired. I tried resetti...
eddie2023
Jun 01, 2023Aspirant
Thanks for your response.. Look at the below answers.
>> Why? What happens that forces you to reset the modem/router?
Wifi just stops working. No internet until I restart my router.
>> The comment about firmware is puzzling. The C7800 is a modem/router. Only your ISP can flash it.
You are correct. I confirmed that I have the latest firmware from my service provider.
>> Your subject says "reset" which is not the same thing as reboot. Which is it?
I unplug the power from the router for 2-3 minutes then plug it back in and the wifi starts working.
This is AC3200 Wifi Cable Modem Router
Model: C7800
Where can I find documentation about troubleshooting? I couldn't find anything helpful. Thank you
michaelkenward
Jun 01, 2023Guru - Experienced User
eddie2023 wrote:
>> Why? What happens that forces you to reset the modem/router?Wifi just stops working. No internet until I restart my router.
2.4 and 5 GHz?
Do the LEDs on the router look right?
>> Your subject says "reset" which is not the same thing as reboot. Which is it?I unplug the power from the router for 2-3 minutes then plug it back in and the wifi starts working.
OK. Reboot. Reset usually means something completely different. You may like to try it.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
