mm_123
Feb 13, 2021Aspirant
C7800 Nighthawk Good upload speed but very low downloads speeds
Hi, I bought a C7800 Nighthawk Cable Modem Router in last Sept 2020 and 5 months now having issues with download speed dropping to nearly zero. Restarting router throughNetgear Genie sometimes so...
Feb 13, 2021Guru - Experienced User
do you have a screen snip of the cable connections page and the logs?
those help us check the line.
If you have any splitters, amplifiers, or attenuators in line, i'd recommend removing them. Check the link for kinks, damage, loose/old/bad/cheap/corroded connections.
mm_123
Thank you so much for getting to this so quickly.
I have removed the spiltter and the line is not chipped anywhere.
Attaching some recent logs, are they enough?
- plemansFeb 13, 2021Guru - Experienced User
those are the router logs.
There are modem logs. Called event logs.
Also, a screen snip of the cable connections page. The cable connections page shows upstream/downstream data
- mm_123Feb 13, 2021Aspirant
Please find both of those attached.
Additionally I have changed the channel to use the least used one in my neighbourhood.
- plemansFeb 14, 2021Guru - Experienced User
Your power levels are very high.
Optimal is -7.5dbmv to 7dbmv. functional (not optimal) is around -13dbmv to 13dbmv.
you're hitting in the 15's. and you have errors in the line and logs.
I usually tell people to remove a splitter/attenuator but in your case an attenuator or a 3-4x splitter might help your signal. Just make sure you get a quality one.
