albreyer
Mar 11, 2024Aspirant
C7800 Nighthawk X4S AC3200 WiFi Cable Modem Router won't factory reset
Try as I might, holding the reset button forever, using the 30/30/30 approach, etc., I cannot seem to get the admin password to change back to password. After 3 failed attempts, I continue to get a...
- Mar 11, 2024
Does this happen with a different browser? Try MS-Edge, Firefox or Opera.
Disconnect the ISP coax cable from the modem as well before trying a factory reset.
albreyer
I'm trying on my computer via a browser:
and also trying with the Nighthawk app on my phone.
The browser does recognize the serial number. I tested this by putting in a bad one on purpose once to see what would happen that way (I don't get the security questions).
- FURRYe38Mar 11, 2024Guru - Experienced User
- albreyerMar 11, 2024Aspirant
I don't recall seeing that solution online before. Disconnecting the coax got me over the hump.
Thank you kindly for the quick responses and expert advice.
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
