albreyer
Mar 11, 2024Aspirant
C7800 Nighthawk X4S AC3200 WiFi Cable Modem Router won't factory reset
Try as I might, holding the reset button forever, using the 30/30/30 approach, etc., I cannot seem to get the admin password to change back to password. After 3 failed attempts, I continue to get a...
- Mar 11, 2024
Does this happen with a different browser? Try MS-Edge, Firefox or Opera.
Disconnect the ISP coax cable from the modem as well before trying a factory reset.
Mar 11, 2024Guru - Experienced User
albreyer
I don't recall seeing that solution online before. Disconnecting the coax got me over the hump.
Thank you kindly for the quick responses and expert advice.
- FURRYe38Mar 11, 2024Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
