Retired_Member
Feb 09, 2020C7800 Parental Controls do not work as intended
Steps taken: 1. log into routerlogin.net (IP: 192.168.1.1) and go to parental controls. 2. Download the Circle app on Samsung S8+ and iPhone 11 and ensure the phone is connected to the WiFi network...
vkdelta
Feb 11, 2020NETGEAR Employee Retired
C7800 is not a circle supported devices.
There are only specific models which are circle support. Please use only those devices if you need circle.
https://kb.netgear.com/000044718/What-NETGEAR-routers-support-Circle-with-Disney
- vkdeltaFeb 11, 2020NETGEAR Employee Retired
correction with Grammar typos
C7800 is not a circle supported device.
There are only specific models which are circle supported. Please use only those devices if you need circle.
- Retired_MemberFeb 11, 2020
I had already identified that in the initial post. I also already addressed several follow up questions:
Why is it implemented in the firmware if it's not even supported? What are my options for parental control if the parental controls are rendered useless?However, your answer as an employee, gives me reason to believe the developers of this router are simply incompetent, much like nature of your "answer."
- FURRYe38Feb 11, 2020Guru - Experienced User
Tgere no need to be rude.
Your best option would be to factory reset the C7800 and setup from scratch. Besure to not enable any Circle functions on the modem. I have this came modem and have never encountered this issue. The C7800 performed with no problems for me. I don't use Circle or Armor.
If this modem doesn't seem to meet your needs, then maybe you should find something that does.
Good Luck.
