SheepDog1813
Jun 19, 2018Tutor
C7800 Port Forwarding not working
This post is actually in reference to the Netgear C7800 Cable Modem/AC Router however I couldn't find it to select in the post drop-down list.
It seems I am unable to forward ANY ports for some...
SouthernFried
Jun 23, 2018Aspirant
I tried to connect to VPN over cellular internet and was able to connect. Nothing changed since yesterday, which was the first day having the C7800. Firmware rev is the same and didn’t do factory reset.
Sorry but I can’t replicate the issue you’re having connecting to the IP:Port of the forwarded device via local network connection. Weird indeed.
WafflesMcDuff
Dec 09, 2018Aspirant
I was having this problem too. I did as suggested and reset to factory settings. It immediately triggered a firmware update which fixed the problem. Thanks!
