crabbman
Jul 04, 2021Aspirant
C7800 ROUTER/MODEM: IS IT CAPABLE OF DOING VOIP?
Hello, just wondering if this router/modem can be used to hook up my new gigaset voip telephones so i can do alot of talking? THANK YOU. DOUGLAS
Jul 05, 2021Guru - Experienced User
Voip=voice over internet protocol
There's versions that are integrated into a router that you can directly connect an RJ11 phone to. (like the C7100v if your isp supports it)
Or theres versions like Ooma that does the hosting itself and can connect to any router.
Tough to tell you based of "gigaset voip telephones"
What actual set do you have?
Have you looked up the requirements for it?
crabbman
Jul 05, 2021Aspirant
Hello. and thank you.
i am trying to buy the hx series of gigaset telephones.
not sure about specs. i was told these models work well in a voip system
having problems trying to purchase a voip phone.
Thought gigaset was a great product. i am open to other brands as well
- plemansJul 05, 2021Guru - Experienced User
I would contact gigaset to see whats compatible as I see some require a dect compatible base and others require the router to have dect
https://www.voipsupply.com/blog/voip-insider/what-is-a-dect-base-station/
I've never used anything like it myself (just stuck to cell phones).
I've got a couple family members that use Ooma and love it.
- crabbmanJul 05, 2021Aspirant
GREAT AND THANK YOU FOR NICE LINK.
OOMA,.THANK YOU
not sure why it is so difficult to get a kit (phone, base staion, answering machine for voip?
some companies have some but it is mainly indivdual buying and i am left to figure how to add a seperate purchase of an an answering machine.
oh well i do have alot of time, newly retired. i will just go with that.
Thank you
