sgoodman1138
Sep 16, 2020Aspirant
C7800 shuts off 2.4ghz
Over the past 3 weeks, I have been having trouble with yhe 2.4ghz band on my router. It seems that the 2.4ghz completely drops out (the light goes off on he router) and the only solution is to resta...
sgoodman1138
Sep 26, 2020Aspirant
Thanks for your reply. I have restarted and factory reset the device multiple times and it doesn't seem to correct the issue long term, only short term. I am thinking that you might be correct that this is more of a hardware issue and my device could be failing.
Sep 27, 2020Guru - Experienced User
sgoodman1138 wrote:Thanks for your reply. I have restarted and factory reset the device multiple times and it doesn't seem to correct the issue long term, only short term. I am thinking that you might be correct that this is more of a hardware issue and my device could be failing.
- sgoodman1138Oct 18, 2020Aspirant
Are you possible suggesting channel interferrence? I routinely perform a channel scan so I can select the channel that my neighbor isn't using.
- FURRYe38Oct 18, 2020Guru - Experienced User
What channels are you using? 1, 6 and 11 are recommended on 2.4Ghz.
