JR1960's avatar
JR1960
Follower
Sep 04, 2022
C7800 weak wifi
Best settings to enhance performance have changed some
1 Reply
  • plemans's avatar
    You didn't give us much to go off other than you have a c7800 and weak wifi.
    1. what actual speeds do you get wired?
    2. speeds over 2.4ghz?
    3. speeds over 5ghz?
    4. what device are you testing on?
    5. what have you tried doing to fix the issue?
