aabate7
Jun 28, 2021Aspirant
C7800 WiFi Dramatically slower than Ethernet
Netgear C7800 hardware version V1.07 firmware V3.01.40 I am using Mediacom for cable & internet - Gig download/50M upload. WiFi internet is dramatically slower than Ethernet. Ethernet is gett...
Jun 28, 2021Guru - Experienced User
Wifi 5Ghz AC will never perform as well as wired ethernet nor see any speeds on the down near 900Mpbs. Depending upon devices used, there design and support, most will max out at around 400-500Mpbs depending on how they connect to the modem and howe the modem/router wifi is configured.
https://www.gigacalculator.com/converters/convert-mb-to-mbps.php
If yoru seeing 30MB then you are probably seeing around what the devices support for Mbps speeds
- aabate7Jun 28, 2021Aspirant
I'm seeing 30 Mbps versus 890Mbps - I'd be thrilled with 400-500!
- FURRYe38Jun 28, 2021Guru - Experienced User
So to confirm, are you seeing 30MB or 30Mpbs? There is a difference...
What devices are you speed testing with?
What are the current wifi settings on the modem?
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?- aabate7Jun 28, 2021Aspirant
Yep - used the wrong B/b - 30Mpbs
Speed testing with iPhone 12; SurfacePro 7; and 2 different Dell laptops.
WiFi for 2.4 is Auto
WiFi for 5G is 153 - I will try 40 to 48.
Other WiFis around - loads! I'm in a townhome/villa community - there are at least 10 that come up on my network searches.
