ChefERRiot
Jun 12, 2021Guide
C7800 WiFi not showing up
I have done all the things, called netgear and ISP. My WiFi cut out randomly, fur solid white lights, no WiFi at all. WiFi button does nothing. Hardwiring in gives me internet access but when...
Jul 01, 2021Guru - Experienced User
If the wifi radios are not working,even after a factory reset. You can just disablle them in the UI. Then connect up any other wifi system to the C7800 and continue to use the C7800 as your modem and router as a alternative suggestion. There are better wifi systems out there that are way better than the wifi thats on the C7800.
ChefERRiot
Jul 01, 2021Guide
I've read that people with the same unit are doing that, I plan on using it as a trade in on a new modem and router.
I will never buy/use a NETGEAR product again. Which is sad because I've used them for 18 years.
