herofabled
Jun 30, 2021Follower
c7800 wifi radios not working
i had a power outage and my wifi will not turn back on. in advanced wireless settings they (wifi radios) are enabled but the LED's are not lighting up and i have no wifi networks. Pressing the Wifi b...
Jun 30, 2021Guru - Experienced User
Try pressing the top case wifi button for 5 seconds, LEDs should turn ON.
Try a factory reset by pressing the reset button for 10 seconds then release. Wifi LEDs should turn ON after this....
Try a different power supply with same power specs.
If not, contact NG support for addition help and information.
