ccqpein
Jul 22, 2019Tutor
C7800 Wifi speed is slow
I just bought C7800 several days ago, because I need DOCSIS 3.1 model to support gig speed of Comcast. Then I notice the speed of 5G wifi only have 400Mbits and it should be near 900Mbits to 100...
Jul 23, 2019Guru - Experienced User
What are your current wifi settings for 2.4 and 5Ghz?
HT160Mhz is not supported on the C7800.
ccqpein
Jul 23, 2019Tutor
I always use 5Ghz
- FURRYe38Jul 23, 2019Guru - Experienced User
I.e. Auto speeds, Auto channels, WPA modes? Things like that...
- ccqpeinJul 23, 2019Tutor
2.4 GHz:
Channel: auto
Mode: Up to 1000Mbps
5 GHz:
Channel: 153
Mode: Up to 2165Mbps
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and channel 44 on 5Ghz.
Try setting the Mode from max to one mode lower then max for each radio and test. You can disable the 2.4Ghz radio as well while testing on 5ghz.
Test with different wifi devices for comparison.
