ccqpein
Jul 22, 2019Tutor
C7800 Wifi speed is slow
I just bought C7800 several days ago, because I need DOCSIS 3.1 model to support gig speed of Comcast. Then I notice the speed of 5G wifi only have 400Mbits and it should be near 900Mbits to 100...
ccqpein
Jul 23, 2019Tutor
I always use 5Ghz
Jul 23, 2019Guru - Experienced User
What are your current wifi settings for 2.4 and 5Ghz?
I.e. Auto speeds, Auto channels, WPA modes? Things like that...
- ccqpeinJul 23, 2019Tutor
2.4 GHz:
Channel: auto
Mode: Up to 1000Mbps
5 GHz:
Channel: 153
Mode: Up to 2165Mbps
- FURRYe38Jul 23, 2019Guru - Experienced User
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and channel 44 on 5Ghz.
Try setting the Mode from max to one mode lower then max for each radio and test. You can disable the 2.4Ghz radio as well while testing on 5ghz.
Test with different wifi devices for comparison.- karthiksgNov 25, 2019Initiate
Hi,
I had the same exact problem. very similar settings (2.4G and 5G). I see at most 300Mbps. I once hooked up my ethernet cable to the router and c7800 does see close to 900Mbps on the etheret cable (i.e not a comcast issue).
I cannot see why this is dropping so much.
KG
