BigEdge02
May 04, 2021Aspirant
C7800 with VOIP
Setup: I have the Nighthawk C7800, with Xfinity gigabit internet, and I have VOIP telephone service. The VOIP is conected to the 7800 via an adapter (ATA). Problem: Anytime the 7800 reboots I lose...
BigEdge02
Thank you plemans...
The adapter is from the VOIP provider (Voiply).
Haven't tried leaving the ATA unplugged since our home security system uses it but it would be worth trying to see if the ATA causing the reboots. The reboots seem to happen the same exact time on days that it does it.
I will try the switch. I'm not totally sure, from a tech side of things, how this would change anything but I'm certainly no guru. Simple enough so definitely worth a try.
Thanks again!
May 04, 2021Guru - Experienced User
Try disabling sip alg on the router.
