bmaravan
Jul 18, 2023Aspirant
C7800V2 Connection Drops multiple times a day
Network Provider: COX Router: C7800V2 Firmware: V6.01.07 Connection: Wireless DL/UL Speed Test: 300/ 50 MB Hi there, I am using my C7800V2 for over a year without any issues, recently it star...
- Aug 05, 2023
Thanks everybody. It seems like the 30-30-30 hard reset procedure may have solved my issue so far. Now, I can login to my admin panel wirelessly (remember, I wasn't able to even login when connected with a cable directly to the modem) and most importantly its stable, doesn't drop anymore, pretty fast and I can configure my router. All of that was not possible before. I may still ask my ISP to check on the firmware and my personal decision is, to replace it with a modem and separate router on the long run.
I followed all instructions/ solutions on a page (doesn't let me to leave the link here but its ok, just google "Routerlogin.net not working and follow appulas) until Solution 8, Part 2 hase solved my issue, here are the details that I followed exactly like this:
If you cannot access Routerlogin.net even after the factory reset, then you need to perform 30-30-30 reset (which will clear out the NVRAM of the router and thus solve the problem).
1.Make sure your router is powered on and no cable is connected to it except the power cable. Disconnect every device PC, laptop, etc. from the router.
2.Now press and hold (through a paper clip or a similar object) the Reset button for 30 seconds.
3.Now, while keeping hold of the reset button, unplug the power cable of the router and keep hold of the reset button for another 30 seconds.
4.Then, while keeping hold of the reset button, plug back the power cable and keep hold of the reset button for another 30 seconds.
5.Then release the reset button and wait for one minute.
6.Now unplug the power cable of the router and wait for another 30 seconds.
7.Then plug back the power cable and power on your router.
8.Now connect the router to the internet and then to a PC with an ethernet cable.
9.Now launch a web browser on the PC and hopefully, you can access the Routerlogin.net. If so, do not forget to update the firmware of your router to avoid any future issues (Advanced > Router Update).
Aug 03, 2023Guru - Experienced User
Power is ok on some channels however you have a few channels that are on the high side opposite from where the other channels are. All channels should be around 3db in power across all channels:
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router
I see some correctable that should be zeros but are not too bad.
Any Criticals, Errors or Warnings seen in the event logs needs to be reviewed and resolved by the ISP. Indicates a signal issue on the ISP line up to the modem.
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly. Have the channel power checked for power levels across all channels.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Start with removing any amplifiers, signal attenuators, or splitters from the coax.
From there check the line for kinks, damage, moisture in the line.
Check the connectors for improperly made ends, foil touching the copper coax line, loose connections, bad/old/cheap connectors, or corroded connections. Replace them if you do.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html
bmaravan
Aug 05, 2023Aspirant
- bmaravanAug 05, 2023Aspirant
Very important, the connection does not drop anymore, in fact, it hasn't dropped for the past 6 days.
- FURRYe38Aug 07, 2023Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
