JimG2828
May 02, 2020Tutor
Cable Modem 1000 (CM1000) Port configuration
Everything was working for over a year: Two weeks ago, my AT&T MicroCell (white) stopped communicating (3G) with my Iphone and now the signal "bar" light is flashing red (supposed to be steady green...
- May 04, 2020
JimG2828 wrote:Now, I guess the question is that if or if not my CM1000 modem has the latest update and how - if my internet provider isn't going to update it - how can I first determin the firm ware verison and if it not the latest - how to manually update it?
But thanks for the asistance on the microcell issue!!! . Fixed!!
Glad you got it working.
Sadly you can't update the firmware on the modem. Its locked and not user upgradeable. Only the isp's can update modems.
May 03, 2020Guru - Experienced User
Try this temporarily.
hook the microcell directly to the modem and not include the router.
reboot both devices and see if it works.
reason I say this is ISP's are horrible at updating firmware on modems that are 3rd party. I'd be betting it isn't necissarily the modem causing it.
JimG2828
May 03, 2020Tutor
Beleave it or not - it worked! I disconnected everything and started with the modem only - nothing connected to it. Booted the modem all by itself. Then connected the microcell only to the modem and booted the microcell. It started working. Then I disconnected the microcell, connected the router to the modem and booted the router. Then I moved the the microcell connection to the router (I did not turn off or reboot the microcell) - it was still working.
So, thanks for the solution!
- plemansMay 04, 2020Guru - Experienced User
