MasterMaker
Jan 12, 2016Aspirant
Cable modem CG3000 doesn't show all Network connectins
Hi All, I have a cable modem with an add on newtork switch, the network map wont show IP's on the switch ?
- Jan 14, 2016
MasterMaker
Just depends on the printer it may be located on a sticker or if you have some type of networked interface to log into for the printer it would be in the network settings.
DarrenM
DarrenM
Jan 13, 2016Sr. NETGEAR Moderator
Hello MasterMaker
What type of switch are you using?
DarrenM
- MasterMakerJan 13, 2016Aspirant
Hi Darren, it is a Netgear 5 port GS605
Chris
- DarrenMJan 14, 2016Sr. NETGEAR Moderator
MasterMaker
Does the modem show the Switch at all? and have you tried to do a address reservation for one of the devices then see if it shows up?
DarrenM
- MasterMakerJan 14, 2016Aspirant
Thanks Darrn, no the switch isnt shown at all, Im not sure how to do an address reservation.......
