MasterMaker
Jan 12, 2016Aspirant
Cable modem CG3000 doesn't show all Network connectins
Hi All, I have a cable modem with an add on newtork switch, the network map wont show IP's on the switch ?
- Jan 14, 2016
MasterMaker
Just depends on the printer it may be located on a sticker or if you have some type of networked interface to log into for the printer it would be in the network settings.
DarrenM
MasterMaker
Jan 13, 2016Aspirant
Hi Darren, it is a Netgear 5 port GS605
Chris
DarrenM
Jan 14, 2016Sr. NETGEAR Moderator
MasterMaker
Does the modem show the Switch at all? and have you tried to do a address reservation for one of the devices then see if it shows up?
DarrenM
- MasterMakerJan 14, 2016Aspirant
Thanks Darrn, no the switch isnt shown at all, Im not sure how to do an address reservation.......
- DarrenMJan 14, 2016Sr. NETGEAR Moderator
Mastermaker
Here is a article on how to do this.
http://kb.netgear.com/app/answers/detail/a_id/25722
DarrenM
Hi Darren, Ok, I viewed the link, the instructions looks fine...so I have one device only on the switch, an OKI printer which is working all fine on the network but just isnt appearing on the network map hence I cant find it IP
so.....Do you mean to do an address reservation for the printer ? would I need its mac address ?
