thinkstation
Apr 27, 2020Aspirant
Cable modem CM1000 cant connect to internet
Hello, I recently purchased a CM1000 cable modem and set up Cox Gigablast on the website. they activated my account and said give it 10 minutes. The light for internet never lit up, the only ligh...
Apr 28, 2020Guru - Experienced User
Factory reset the modem.
Have the ISP check the signal and line quality UP to the modem.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
