NicoleMiczek
Oct 28, 2019Follower
Cable Modem CM1000
I need to know if I have to connect this modem to a computer in order for it to work or can I just plug it into the cable and the wall?
Oct 28, 2019Guru - Experienced User
You need to have a PC connected to the modem after you have connected the modem to the cable wall out let. You may need to contact your ISP service to have them help you get it installed and associated with there services.
