gagandeep
Oct 29, 2019Guide
Cable modem CM1100 assigns internal IP to router when either device is rebooted
Hi. I just purchased a cable modem CM1100 and have an issue - each time I reboot the modem (or router), the modem assigns 192.168.100.1 to router and not actual IP address from ISP, such that there i...
- Nov 05, 2019
Ok glad the IP address was resolved by the provisioning.
A couple of ms difference isn't something to worry about, however your choice. If you get a modem for rent free, why not.Please mark your thread as solved so others will know.
Enjoy.
gagandeep wrote:Thank you FURRYe38 for the answer! I did log a ticket with Netgear and got support as the product was new. I was asked to contact ISP for "mac re-provisioning". Once this was done, the issue was resolved.
PS> Returned my CM1100 as the ping time/ latency was few ms higher than Spectrum provided modem. Here is what I found: Motorola MB8600 and CM1100 modems had 11-14ms ping; whereas Spectrum Hitron (possibly Puma chip) had 6-10ms ping and immediately throttled to top allowed speeds. Since ISP gave the modem free, I returned the ones I purchased!
gagandeep
Oct 29, 2019Guide
sorry please read the Ip address line as "modem assigns 192.168.100.10"
