gagandeep
Oct 29, 2019Guide
Cable modem CM1100 assigns internal IP to router when either device is rebooted
Hi. I just purchased a cable modem CM1100 and have an issue - each time I reboot the modem (or router), the modem assigns 192.168.100.1 to router and not actual IP address from ISP, such that there i...
- Nov 05, 2019
Ok glad the IP address was resolved by the provisioning.
A couple of ms difference isn't something to worry about, however your choice. If you get a modem for rent free, why not.Please mark your thread as solved so others will know.
Enjoy.
gagandeep wrote:Thank you FURRYe38 for the answer! I did log a ticket with Netgear and got support as the product was new. I was asked to contact ISP for "mac re-provisioning". Once this was done, the issue was resolved.
PS> Returned my CM1100 as the ping time/ latency was few ms higher than Spectrum provided modem. Here is what I found: Motorola MB8600 and CM1100 modems had 11-14ms ping; whereas Spectrum Hitron (possibly Puma chip) had 6-10ms ping and immediately throttled to top allowed speeds. Since ISP gave the modem free, I returned the ones I purchased!
Oct 29, 2019Guru - Experienced User
Have you factory reset both CM and R units and setup up from scratch. Usually takes about a minute or two for the WAN side ISP address to come thru possibly to the R router. To check this, wire connect a wired PC directly to port #1 on the CM modem. After it comes to ready, watch the networking status on your PC. It should change to the WAN IP address that your ISP gives out.
Might contact your ISP and have them help you this this. Check the line quality up to the modem. Ensure the modems correctly associcated with there system.
- gagandeepNov 04, 2019Guide
- FURRYe38Nov 05, 2019Guru - Experienced User
Enjoy.
