hshinshaw
May 08, 2021Follower
cable modem CM400 update problem
My internet has been out for about two weeks. I first contacted my internet provider(Xfinity) and after calling multiple times and even having a technician come in, they told me that the modem tried t...
michaelkenward
May 09, 2021Guru - Experienced User
hshinshaw wrote:
My internet has been out for about two weeks. I first contacted my internet provider(Xfinity) and after calling multiple times and even having a technician come in, they told me that the modem tried to go through an update and then the update failed somehow.
That sounds like rubbish. The only way that your modem can update is if your ISP started it. This is not something you can do.
If your firmware is outdated, you cannot manually upgrade your cable modem’s or modem router’s firmware. You must contact your Internet service provider (ISP) to upgrade your firmware.
This is odd:
hshinshaw wrote:
The power is fine, the internet connection is fine, but only the red power light shows.
That suggests that the power is not fine. Do you have another power adapter you can try with the correct specifications?
The power :ED should be green. Red does not seem to exist.
If only the [pwer LED is on, then the Internet connection is not fine.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Check the section in the manual Troubleshoot With the LEDs.
You may have done that already. I can't tell from your message.
I mention it because Netgear gave up on supplying paper manuals years ago and people sometimes miss the downloads.
Your modem dates back to 2015. Your description smells more like hardware failure than anything else.
You have posted your message in the section of this community given over to Nighthawk WiFi Routers. (This is easily done, given Netgear's complicated community structure.)
Many questions apply to different types of device, so you might get responses here, but you might get more help, and find earlier questions and answers specific to your hardware, in the appropriate section for your device. That's probably here:
Cable Modems & Routers
I will ask the Netgear moderator to move your message.
