mohrfam
May 21, 2020Aspirant
Cable Modem CM500V needs to be restarted daily to maintain download speed
My contracted download speed with Xfinity is 325 MBsec but I often find downloads are running around 10 mb/sec. My way to fix the porblem is by unplugging the power on my CM500V modem, waiting 10 sec...
May 22, 2020Guru - Experienced User
Log into the cm500v and get a screen snip of the cable connection page and your logs.
Post those back here. Also, if you have any splitters, amplifiers, attenuators in line, remove them.
What router are you connecting it to?
What speeds do you actually get hardwired into the modem?
And hardwired into the router?
- mohrfamMay 22, 2020AspirantRouter is Netgear R6700v2 Screen snip: Apply Cancel Frequency start Value This field below allows you to modify the frequency the cable modem start with its scan during initialization and registration. Enter the new start frequency and restart the cable modem for it to take effect. Starting Frequency 0 Startup Procedure Procedure Status Comment Acquire Downstream Channel 597000000 Hz Locked Connectivity State OK Operational Boot State OK Operational Security Enabled BPI+ IP Provisioning Mode Honor MDD honorMdd(4) Downstream Bonded Channels (Partial Service) Channel Lock Status Modulation Channel ID Frequency Power SNR Correctables Uncorrectables 1 Locked QAM256 32 597000000 Hz -6.1 dBmV 34.2 dB 38172 17357 2 Locked QAM256 20 525000000 Hz -7.6 dBmV 36.8 dB 43061 43261 3 Locked QAM256 21 531000000 Hz -7.6 dBmV 37.2 dB 41754 41146 4 Locked QAM256 22 537000000 Hz -7.5 dBmV 37.6 dB 40123 35139 5 Locked QAM256 23 543000000 Hz -7.3 dBmV 37.5 dB 40523 31794 6 Locked QAM256 24 549000000 Hz -7.2 dBmV 36.1 dB 39887 27585 7 Locked QAM256 25 555000000 Hz -7.2 dBmV 29.4 dB 321864 22855 8 Locked QAM256 26 561000000 Hz -7.1 dBmV 31.6 dB 46796 22670 9 Locked QAM256 27 567000000 Hz -6.9 dBmV 28.9 dB 9807098 41413 10 Locked QAM256 28 573000000 Hz -6.8 dBmV 30.8 dB 66428 22511 11 Locked QAM256 29 579000000 Hz -6.6 dBmV 34.5 dB 40879 20233 12 Locked QAM256 30 585000000 Hz -6.5 dBmV 32.1 dB 47280 20163 13 Locked QAM256 31 591000000 Hz -6.2 dBmV 33.9 dB 39096 17659 14 Not Locked Unknown 33 603000000 Hz 0.0 dBmV 0.0 dB 0 0 15 Not Locked Unknown 34 609000000 Hz 0.0 dBmV 0.0 dB 0 0 16 Locked QAM256 35 615000000 Hz -5.7 dBmV 37.3 dB 33649 16081 Upstream Bonded Channels Channel Lock Status US Channel Type Channel ID Symbol Rate Frequency Power 1 Locked ATDMA 1 5120 Ksym/sec 17300000 Hz 53.5 dBmV 2 Locked ATDMA 3 5120 Ksym/sec 30300000 Hz 54 dBmV 3 Locked ATDMA 5 1280 Ksym/sec 41200000 Hz 54 dBmV 4 Locked ATDMA 4 5120 Ksym/sec 36700000 Hz 54 dBmV Current System Time:Fri May 22 11:35:59 2020 System Up Time:14:20:46
- plemansMay 22, 2020Guru - Experienced User
please do it in a screen snip form. copy and pasting makes it a challenge to read/compare.
https://support.microsoft.com/en-us/help/13776/windows-10-use-snipping-tool-to-capture-screenshots
