Stealth16
Jan 21, 2017Follower
Cable Modem CM600 stuck in IPv6 mode - how do I get it reset?
I have had TWC internet as my ISP for several years and have been using my own Cable Modem, CM600 with no issues. I recently switched to WOW internet as my ISP. The installer came and upon attem...
DarrenM
Jan 26, 2017Sr. NETGEAR Moderator
Hello Stealth16
I would suggest contacting Netgear support if the modem is under warranty they might be able to help you with this.
https://www.netgear.com/support/contact.aspx?cid=wmt_netgear_organic
DarrenM
