Selest
Jun 04, 2018Aspirant
Cable Modem CM700 T3 and T4 Errors in logs.
So I've been having continuing internet problems over the past month, where overtime when I'm playing a video game or watching something online, it will literally become unplayable or watchable becau...
vkdelta
Jun 04, 2018NETGEAR Employee Retired
Please post connection table and event logs screenshots.
Selest
1 - https://gyazo.com/5ab148af8229798af6236df22befa01e
2 - https://gyazo.com/e3deda6df33513eaa504c7ea8d08d5b7
Not sure which one is the connection table. If none of these are please let me know where it is.
1 - https://gyazo.com/3eefdeaae2a3d04cd6c342035d19ca19
- vkdeltaJun 04, 2018NETGEAR Employee Retired
your signals on your line is completely out of whack.
in Downstream you have thosands on uncorrectables. No wonder you are losing packets
in upstream you have 2 channels which are maxing out upstream power at 51dBmV. you will see some internet disconnections if the power goes beyond this.
there is no question that your line quality is bad. I would be surprised if the cox tech says line is good and modem is bad.
to get a 3rd party opinion, you can post your signal stats on DSLreports.com forum and post.
https://www.dslreports.com/forum/coxhsi
https://www.dslreports.com/forum/comcast
generally comcast forum has better response rates.
- SelestJun 04, 2018AspirantSo you definitely don’t think it’s the modem? I was get furious with the support, since I just bought a brand new one. And to be clear the Cox SUPPORT said it was a problem with my modem each time. The technician literally ran a new wire from the pole to our house hoping it would fix it. Do you think it has to do with the outside lines in the area?
Also what do you think I should tell the technician? I’m having the THIRD technician come to our house tomorrow to figure things out.- vkdeltaJun 05, 2018NETGEAR Employee Retired
as long as you have good Coax cables and you have connected/tightened it properly, it should not be modem issue.
as I mentioned, you can try posting your logs on other forums where many other folks will comment and provide their opinion.
If it really a modem problem, you can ask them to put their 32x8 modem (not 8x4 or 16x4) and prove it to you that there are 0 uncorrectables and US power is not hitting 51dBmV. Dont just put the cox modem for 5 mins to prove. Run heavy traffic on the modem (including multiple speedtests, netflix, and large file downloads to prove it). Sometimes they just connect for 5 mins and tell you "see, no error, it is your modem problem". the uncorrectables increase when there is lot of traffic.
you want to show US power is very high to technician
You want to show very high number of uncorrectables to technician.
