allen1062's avatar
allen1062
Cable Modem Router stopped working
Coax wire fell out and wouldn't work after being plugged back in. Did a power cycle and did a factory reset. Now all the lights are on and nothing responds. Any idea what to do to fix it?
  • FURRYe38's avatar
    How do you mean the coax fell out? Did the coax wired come out from its connecting screw plug jack? If so, possible ground and center wires maybe touching when they shouldn't be. Id have someone check that connetion to be sure it's correctly wired and the screw jack is in place correctly.
    Power OFF the modem. Pull power adapter as well. Disconnect the coax screw jack from the modem fully. Disconnect ALL LAN cables as well.
    Power ON the modem WITH OUT the coax connected. Do all lights turn on all the time or just the power and do the other LEDS start to blink?
    Try pressing the reset button for 10 seconds then release with out coax cable connected.
    • allen1062's avatar
      allen1062
      Somehow it came loose and when I went to check it, it came out of the socket. All the lights are on and stay on. Once in a while they all blink once or twice. I've checked all the connections and ground wire that I am able to and they are not touching. I've done the recommendation you gave with no success.
      • plemans's avatar
        Have you tried replacing the coax cable and then rebooting the modem?
