timstring
Oct 07, 2020Aspirant
Cable Modem will not load a config file
My venerable C6300 is connected to Suddenlink in Abilene, TX. I am supposed to have 400 Mbps service, but it has been down for 10 days. I have had all sorts of issues with Suddenlink's lack of cust...
Oct 07, 2020Guru - Experienced User
do you have a screen snip of the full log and the cable connections page?
That's helps more than just 1 item from it.
Also, if you have any splitters, amplifiers, attenautors in the coax line, I'd remove them.
- timstringOct 07, 2020Aspirant
Here is the whole event log. As you can see, there are T3 errors, but not enough to kill it. I will have to get the cable diagnostics when I get back home, but the levels are in spec when there is a 2-way splitter between the modem and the wall. On a straight coax connection, the levels on all 16 downstream channels are around +8.5dBmV--high but not lethal. With the 2-way, the are all around 5.0 dBmV. I do have a maintenance tech scheduled to check the levels at the tap, and he is going to have to go to the closest trunk amp and dial it down a bit.
Time Priority Description Oct 07 2020 06:27:32 Warning (5) MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1 Time Not Established Error (4) Primary lease failed, IPv4 fallback initiated Time Not Established Critical (3) DHCP failed - RS sent, no RA received Time Not Established Critical (3) No Ranging Response received - T3 time-out Oct 06 2020 22:22:29 Warning (5) MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1 Time Not Established Error (4) Primary lease failed, IPv4 fallback initiated Time Not Established Critical (3) DHCP failed - RS sent, no RA received Time Not Established Critical (3) No Ranging Response received - T3 time-out Oct 06 2020 22:11:31 Warning (5) MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1 Time Not Established Error (4) Primary lease failed, IPv4 fallback initiated Time Not Established Critical (3) DHCP failed - RS sent, no RA received Oct 06 2020 22:00:05 Warning (5) MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1 Time Not Established Error (4) Primary lease failed, IPv4 fallback initiated Time Not Established Critical (3) DHCP failed - RS sent, no RA received Time Not Established Critical (3) No Ranging Response received - T3 time-out Oct 06 2020 21:27:19 Warning (5) MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1 Time Not Established Error (4) Primary lease failed, IPv4 fallback initiated Time Not Established Critical (3) DHCP failed - RS sent, no RA received Oct 06 2020 21:18:14 Warning (5) MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1 Time Not Established Error (4) Primary lease failed, IPv4 fallback initiated Time Not Established Critical (3) DHCP failed - RS sent, no RA received Time Not Established Critical (3) No Ranging Response received - T3 time-out Oct 06 2020 13:18:33 Critical (3) SYNC Timing Synchronization failure - Loss of Sync Oct 06 2020 12:44:17 Critical (3) No Ranging Response received - T3 time-out Oct 06 2020 10:44:30 Critical (3) SYNC Timing Synchronization failure - Loss of Sync Oct 06 2020 06:38:33 Warning (5) MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1 Time Not Established Error (4) Primary lease failed, IPv4 fallback initiated Time Not Established Critical (3) DHCP failed - RS sent, no RA received Time Not Established Critical (3) No Ranging Response received - T3 time-out Oct 06 2020 06:33:31 Warning (5) Lost MDD Timeout Oct 06 2020 06:33:26 Critical (3) SYNC Timing Synchronization failure - Loss of Sync Oct 05 2020 21:01:00 Warning (5) MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1 Oct 05 2020 21:00:55 Error (4) Primary lease failed, IPv4 fallback initiated Oct 05 2020 21:00:55 Critical (3) DHCP failed - RS sent, no RA received Oct 05 2020 21:00:33 Critical (3) No Ranging Response received - T3 time-out Oct 05 2020 20:59:09 Warning (5) MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1 Oct 05 2020 20:59:02 Error (4) Primary lease failed, IPv4 fallback initiated Oct 05 2020 20:59:02 Critical (3) DHCP failed - RS sent, no RA received Oct 05 2020 20:58:38 Critical (3) No Ranging Response received - T3 time-out Oct 05 2020 20:31:23 Warning (5) MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1 Oct 05 2020 20:31:23 Warning (5) MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1 Oct 05 2020 20:31:23 Warning (5) MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1 Oct 05 2020 20:31:23 Warning (5) MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1 Oct 05 2020 20:31:23 Warning (5) MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1
