Time | Priority | Description |
Oct 07 2020 06:27:32 | Warning (5) | MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1 |
Time Not Established | Error (4) | Primary lease failed, IPv4 fallback initiated |
Time Not Established | Critical (3) | DHCP failed - RS sent, no RA received |
Time Not Established | Critical (3) | No Ranging Response received - T3 time-out |
Oct 06 2020 22:22:29 | Warning (5) | MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1 |
Oct 06 2020 22:11:31 | Warning (5) | MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1 |
Oct 06 2020 22:00:05 | Warning (5) | MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1 |
Oct 06 2020 21:27:19 | Warning (5) | MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1 |
Oct 06 2020 21:18:14 | Warning (5) | MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1 |
Oct 06 2020 13:18:33 | Critical (3) | SYNC Timing Synchronization failure - Loss of Sync |
Oct 06 2020 12:44:17 | Critical (3) | No Ranging Response received - T3 time-out |
Oct 06 2020 10:44:30 | Critical (3) | SYNC Timing Synchronization failure - Loss of Sync |
Oct 06 2020 06:38:33 | Warning (5) | MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1 |
Oct 06 2020 06:33:31 | Warning (5) | Lost MDD Timeout |
Oct 06 2020 06:33:26 | Critical (3) | SYNC Timing Synchronization failure - Loss of Sync |
Oct 05 2020 21:01:00 | Warning (5) | MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1 |
Oct 05 2020 21:00:55 | Error (4) | Primary lease failed, IPv4 fallback initiated |
Oct 05 2020 21:00:55 | Critical (3) | DHCP failed - RS sent, no RA received |
Oct 05 2020 21:00:33 | Critical (3) | No Ranging Response received - T3 time-out |
Oct 05 2020 20:59:09 | Warning (5) | MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1 |
Oct 05 2020 20:59:02 | Error (4) | Primary lease failed, IPv4 fallback initiated |
Oct 05 2020 20:59:02 | Critical (3) | DHCP failed - RS sent, no RA received |
Oct 05 2020 20:58:38 | Critical (3) | No Ranging Response received - T3 time-out |
Oct 05 2020 20:31:23 | Warning (5) | MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1 |
