drminton
Oct 25, 2017Aspirant
Cable Modem Wireless Connections - No Internet - limit of 3
I have a setup with a CM400 cable modem and an N300 wifi router both at my home and my office. At my home I have roughly a dozen wireless connected devices (laptops, Rokus, phones, etc.), but in my o...
- Nov 02, 2017
Did a factory reset and all devices are now connecting to Internet as well as wireless. Thanks for the help.
DarrenM
Oct 27, 2017Sr. NETGEAR Moderator
Have you tired to factory reset the router and make sure you have the latest firmware?
DarrenM
drminton
Oct 27, 2017Aspirant
It is a fresh out of the box install with the firmware upgrade.
- DarrenMOct 27, 2017Sr. NETGEAR Moderator
Do you have a different SSID for the one in the office than the one on the home?
DarrenM
- drmintonOct 27, 2017AspirantYes. There are two different SSIDs. They should also not interfere with one another. They are in two different buildings. I Can't find a setting on either side that makes one different from the other.
