drminton
Oct 25, 2017Aspirant
Cable Modem Wireless Connections - No Internet - limit of 3
I have a setup with a CM400 cable modem and an N300 wifi router both at my home and my office. At my home I have roughly a dozen wireless connected devices (laptops, Rokus, phones, etc.), but in my o...
- Nov 02, 2017
Did a factory reset and all devices are now connecting to Internet as well as wireless. Thanks for the help.
drminton
Oct 27, 2017Aspirant
It is a fresh out of the box install with the firmware upgrade.
DarrenM
Oct 27, 2017Sr. NETGEAR Moderator
Do you have a different SSID for the one in the office than the one on the home?
DarrenM
- drmintonOct 27, 2017AspirantYes. There are two different SSIDs. They should also not interfere with one another. They are in two different buildings. I Can't find a setting on either side that makes one different from the other.
