GrampsCO
Apr 10, 2019Aspirant
Cable modem with voice
The specs and user guide on the CM1150V-100NAS cable modem with voice do not say if the telephone connector on the back supports obly one phone or a group of parallel connected phones like normally f...
Apr 10, 2019Guru - Experienced User
There is two Phone jacks in the back. Wheather or not there are for separate phone line numbers or same, NG support would be able to answer that:
https://www.netgear.com/images/datasheet/networking/CableModems/CM1150V.pdf
Also this would connect to your home phone networking so you would have a place where all your phone connect too, then this would connect to that central location.
I would also ask your ISP if this modem model is supported on there system. This modem is for cable ISPs with phone support thru the modem.
GrampsCO
This model is recommended by my cable company (Comcast) so OK there. I have 250MBPS so OK there. Specs sheet says second phone jack is for a second phone line so I can't use it.
