Ern-S's avatar
Ern-S
Tutor
May 03, 2022
Cable modem won't connect to Mac with J45
I have a brand new C6300V2 cable modem/router that is connected to my Spectrum service and the wireless part (after some issues) works fine with my desktop Mac and with other devices. But, when I plug the cable from the yellow J45 output jack to the Mac's input, The Mac will not recognize the modern and the wired light flashes constantly. ???  Any ideas anyone?
  • Ern-S's avatar
    Ern-S
    May 05, 2022
    The end of this story is apparently my Mac was damaged by the lightning strike and the Ethernet (J45 connector on the back) will no longer make a wired connection to the modem/router. I blamed the modem/router at first because I couldn’t get my TV connected to wired Ethernet either, but that was a wiring error on my part. The modem/router device works fine. The lightning took out my old modem/router, either my TV or amplifier ARC function, and my Mac desktop Ethernet port. That much so far.
    Case closed.
  • ps Setup on Mac side it TCP/IP, IPv4 Address: 169.254.9.111, Configure IPv4: using DHCP
    • plemans's avatar
      all other wired devices work fine?
      Just the one mac?
      Does that mac work over wireless?
      • Ern-S's avatar
        Ern-S
        Tutor
        One Mac but my LG TV won’t connect, either, via a wired connection. I thought this connection via a wired J45 connection was automatic. What settings need to be made beyond what I listed? Again, all wireless connections are up and running on multiple devices.
