pjackson9
May 20, 2020Follower
Cable Modem
I'm using the Nighthawk CM12000 cable modem with Xfinity as my ISP. I have an ethernet cable in port 1 going to my PC. The PC can access the internet without any problems. I have another ethernet ...
May 21, 2020Guru - Experienced User
What happens if you connect your wifi router to port #1 and your PC to the back of the wifi router?
pjackson9 wrote:I'm using the Nighthawk CM12000 cable modem with Xfinity as my ISP. I have an ethernet cable in port 1 going to my PC. The PC can access the internet without any problems. I have another ethernet cable in port 2 going to my Nighthawk X6S (model: R8000P). It is not getting a connection to the internet. I tried all three ports on the back of the cable modem with no luck.
It seems like only port 1 is working on the back of the cable modem. I tried to reset the modem by holding the reset button for 30 seconds. I was hoping that it would erase the password that was setup, but I still cannot log into the modem with the default username & password. And port 1 is still the only one that works. I moved the cable (on port 1) from my PC and connected it to the router, and it worked.
