DWalk74's avatar
DWalk74
Cable Modem
Need help I was thinking about buying a cable modem to replace my AT&T modem but haven't seen if any of the Netgear modems that say they are compatible with At&t.
  • > [...] a cable modem to replace my AT&T modem [...]
       Why?  Is there some actual problem which you are trying to solve?
       What is your "my AT&T modem"?  Maker?  Model?  Is it a DSL
    modem(+router?), or a cable-TV-type modem(+router?), or what?
       Possession of some basic information about what you have might make
    it easier to choose a suitable replacement for it.
    • DWalk74's avatar
      DWalk74
      I have an AT&T Uverse Arris Bgw210 700 Gateway
      • antinode's avatar
        antinode
        Guru
           As a quick Web search would reveal, that's a DSL modem+router;
        different technology from cable-TV.  If you're keeping the same Internet
        service, then a "Cable Modem" would be useless to you.
        > [...] Is there some actual problem which you are trying to solve?
           Still wondering.
  • FURRYe38's avatar
    what is the model # of the modem you currently have?
    It's best to check with ISPs first to see that they support. Some ISP don't allow for user owed modems.
