drmax1111
Oct 25, 2023Aspirant
Can’t change my network name
I have a Nighthawk C6220. Recently had to reset my unit. I want to change my network name from Netgear 88 to a different name but it will not allow says it cannot connect to the router yet I have perf...
- Oct 25, 2023
Are you using a wired PC and web browser to factory reset the modem and setup from scratch walking thru the setup wizard with the browser? MS Edge or Firefox is recommended here.
Oct 25, 2023Guru - Experienced User
- drmax1111Oct 25, 2023AspirantI was able to use the IP address in url bar log on method. Worked on my phone. Did not the other night. Successfully changed network name. Thank you and case close!
- FURRYe38Oct 25, 2023Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
