drmax1111's avatar
drmax1111
Can’t change my network name
I have a Nighthawk C6220. Recently had to reset my unit. I want to change my network name from Netgear 88 to a different name but it will not allow says it cannot connect to the router yet I have perf...
  • FURRYe38's avatar
    Oct 25, 2023
    Are you using a wired PC and web browser to factory reset the modem and setup from scratch walking thru the setup wizard with the browser? MS Edge or Firefox is recommended here.
