Vso316
Apr 19, 2020Follower
Can’t connect to my N300 WiFi router (Model WNR2000v5)
I connected my router to the modem. All of the lights are green and I was able to connect my iPhone earlier today when I initially activated my xfinity service. Now, I can’t connect at all. I tried us...
Apr 19, 2020Guru - Experienced User
What xfinity router are you connected to? (model)
running 2 routers on the same network puts you in a double nat. If the xfinity device is a modem/router combo device, the xfinity either needs to be put in passthrough mode or the netgear in AP (access point) mode.
- Shawn_171992Apr 19, 2020AspirantI had that same issue. I upgraded to the nighthawk ac1900 modem router & now my speeds have doubled!
- plemansApr 19, 2020Guru - Experienced User
The OP might even see better gains depending on their service. The wnr2000 is a pretty old N300 single band 10/100mbps device. pretty base level router even when it came out.
