HenryTang's avatar
HenryTang
Can’t join WiFi on CAX30
  • Looks like the CAX30 has Access Control settings configured to block your iPhone from connecting to the wifi network. Either the phone's MAC address specifically isn't allowed to connect or Access Control has been set to block all new devices from connecting to the network, which may very well be your problem if you never connected to it before.
    If you give us more information to work with, that would help a lot because you're not giving us much to go on with only a screenshot.
      • HenryTang's avatar
        HenryTang
        After setting up my new CAC30 cable modem router, I still can’t join WiFi.
