HenryTang
Jul 16, 2022Aspirant
Can’t join WiFi on CAX30
- Jul 17, 2022
Looks like the CAX30 has Access Control settings configured to block your iPhone from connecting to the wifi network. Either the phone's MAC address specifically isn't allowed to connect or Access Control has been set to block all new devices from connecting to the network, which may very well be your problem if you never connected to it before.
If you give us more information to work with, that would help a lot because you're not giving us much to go on with only a screenshot.
HenryTang
Jul 17, 2022Aspirant
Hi Ryan,
1, device setup by myself.
2, I got it from Costco few days ago since on sale right now.
3, that is brand new.
4, Yes, I am using the Nighthawk mobile app.
5, My iPhone is the only one got blocked. My wife and my two daughters iPhone and their laptops are connected without any issue. My laptop connection is good too.
iRyan
Jul 18, 2022Star
So it definitely sounds like your iPhone was blocked somehow in the Access Control settings. All you have to do to fix that is remove it from the block list. You can do that by logging into the routerlogin.net config page, select the Advanced tab, select the Security option and check Access Control. Good luck!
- HenryTangJul 18, 2022AspirantHi Ryan,
I followed your instructions to uncheck the private WiFi address then I can connect to WiFi but I have other concern. It pops up a warning window for turn off the private WiFi address. Will that be a problem?- FURRYe38Jul 18, 2022Guru - Experienced User
That's a Apple feature:
If your at home, WiFi Private Address is not needed while your at home.
- iRyanJul 18, 2022Star
As FURRYe38 stated earlier, it's totally safe to disable the Private WiFi Address option on your home network. My personal recommendation is to never use the private address feature on a home WiFi network, as it randomizes the phone's MAC address and will make certain parts of advanced router configuration a little more tedious. Most of the time a random MAC address is only beneficial for public WiFi networks, where an extra layer of privacy is warranted to prevent you from being tracked.
- HenryTangJul 19, 2022AspirantHi Ryan,
My wife’s own laptop can connect to WiFi except her company’s laptop. Is there anything I can do to make it work ?
