Benzo14
Nov 04, 2017Follower
Can’t login after hard reset
So I got this router from my parents, and I hard reset it but I don’t know the original password to connect via WiFi to reconfigure the settings. Is there a way I can connect to change the settings?
antinode
Nov 04, 2017Guru
> [...] I hard reset it [...]
How hard? Visit http://netgear.com/support , put in your model
number, and look for Documentation. The User Manual explains the
procedure. Look for "Factory Default Settings".
> but I don't know the original password to connect via WiFi to
This information is often found on the product label on the router.
If that fails, try a wired connection.
