garfeeld
Sep 05, 2020Follower
Can a C7100v be setup as an access point?
I need to upgrade my modem to be able to use 1g speed and I currently have a c7100v , and one of the compatible modems listed that support the 1g speed is the CM1150v, but it lacks wifi for some reason.
Now , since my c7100v does have wifi, i have looked into different options that from my limited understanding do not seem to do what i need, which is to still have wifi, meaning bridge mode does not seem to do what i want, but making the c7100v an access point seems too.
But looking at some setup for making a router an access point talks about connecting an ethernet cable to the routers WAN port, which he 7100 only has 4 LAN ports i thought?
So basically is it possible to use my 7100 as an access point so i still have wifi? or would i have to buy another router ? which honestly would suck.
ps. the voice capablity is something i need as well.
1 Reply
> have a c7100v , [...]A Cxxxx model is a modem+router, not a simple modem.
> [...] and one of the compatible modems listed that support the 1g
> speed is the CM1150v, but it lacks wifi for some reason.A CMxxxx model is a modem (only). It lacks all router functionality.
> [...] making the c7100v an access point seems too.
Nope. You could do that, but you'd still need a router. Sadly,
without an Ethernet WAN/Internet port, a Cxxxx model can be used as a
modem+router, but not as a plain-old router (with another modem).Now you know one good reason to avoid cable modem+router combination
units.> [...] or would i have to buy another router ? [...]
Yup.> ps. the voice capablity is something i need as well.
I know nothing, but I'd guess that the "V" on the modem model number
would cover that part.If you get a router (with an Ethernet WAN/Internet port), and you're
still interested in configuring your C7100V as a wireless access point,
then see, for example:https://community.netgear.com/t5/x/x/m-p/1463500
That's written for a Netgear C6300-as-WAP, but the steps are about the
same for any other router (any make/model) which lacks a one-step WAP
option. (I'd expect a C7100V to be very similar.)
